69 ball joint removal - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Just wondering if anyone knows how to separate the ball joint from the spindle without damaging the boot or stud? The old fork and hammer method that I used to use for flat rate in the garage is not my prefered method,if you know what I mean. Thanks
    Re: 69 ball joint removal
    Greg-----
    Two methods:
    1) The "dual hammer" method described in the service manual;
    2) A 2 jaw press type tool with a screw-type mandrel. Old Forge makes one that works well for both ball joints and tie rod ends.
    • Frank H.
      • May 22, 2013
      • 148
      the two hammer!
      since their cone or wedge fit,only takes a slight compression to pops them out.
      but don't use a ball peen
      FH
