I would like to hear from those who stores a C2 for the winter. I currently drive my 67 coupe every week to week and a half to keep the battery up. Normally this is more of a pleasure than a job, however, every once in a while for various reason driving is not possible in a timely manner and when I get around to it the battery is not strong enough to start the car. The garage is not heated. My choices seam to be a) a battery "heater" not capable of charging but able to keep the battery warm so as to hole a charge, b)a battery charger with low voltage and higher voltage charging capabilities, and c.) a battery charger/starter.
I would like to hear from others who have faced this problem. How have you solved the problem? What are the pros and cons of my options?
