A few sources, including the TIM&JG state that 215/70R-15 is the recommended radial replacement size for F70-15. The tire size specs I have seen bear this out; however, none of the measurement charts I have seen use an 8 inch rim. In fact, most only show a range of 5.5-7.0 inches. So while the dimensions match up on paper, they are taken on a narrower rim.
I don't like the look of 225s or 235s- they are too massive, and I want the stock size appearance. Is the 215/70R indeed the tire to use? Also, I want to do the white stripe version, so I am considering having Diamondback make them up. Any other options out there for this size tire with the thin white stripe of early '70s? THANKS.
