Re: Rear wheel bearings - should I try it??
Without a lift I wouldn't attempt this repair. There are two primary areas of difficulty in this type of repair. First, getting the trailing arms out is no simple matter, even though on paper it looks easy. Second, removing the spindle from the housing is even harder. Trying to remove the spindle with the trailing arm still installed can be enormously frustrating, and screw or slide hammer tools are seldom up to the task. Besides, if the bearings need replacing, no doubt the bushings are shot also.
I designed a tool from steel plate and threaded rod for use with a hydraulic press that is easy, safe and reliable. E-mail me at mghaluska@aol.com and I can send you a photo of the tool.
I also recommend taking the spindle to a machine shop and have the shaft turned so the INNER BEARING is a slip fit. This will simplify removal next time while not adversely affecting the service life of the bearing.
