1965 Air Conditioning - NCRS Discussion Boards
  • Dick Grattan
    Hi, I am looking for some help or information. I have a 1965 coupe 350hp w/ac. The car had the air removed some time ago and I am slowly getting the parts to put it back in working condition. I recently aquired the outer and inner boxes. On the outer box there appears to be two brackets?? which have been hacksawed off leaving the base. Both are spot welded to the cover of the evaporator. One bracket is above the resistor and to the right. The 2nd is below the resistor and to the right, near one of the evaporator bolt holes.
    Most of the photos that I have seen in the REstoration & Tech Guide Vol 2 do not give a clear photo of the evaporator.
    Does anyone have an idea 1) what the brackets were used for, POA or Expansion valves? 2) are the brackets specific to a year?
    If anyone has digital photos of the evaproator or outer box of a functioning AC, to share, it would be greatly appreciated.
    Dick
  • Wayne M.
    • March 1, 1980
    • 6414
    • Dick Grattan
      Re: 1965 Air Conditioning
      Wayne
      First thanks for dropping me a note. The bracket you see is one of the brackets that I am interested in. Can you describe how the bracket attaches to this pipe? i.e. how long the perpendicular portion is, does it taper etc etc. On mine the base is about 1" and I am assuming the piece or part that attaches to the pipe is hidden under that putty like stuff.
      The 2nd bracket seems to be very close in location to the 2nd one you describe. I do have the two studs that hold the Suction Throttling Valve bracket, but that bracket can be removed. The one I am interested in is about 4" above the mid point between the two studs. Since have a 65 yo look at I suspect this bracket might have been used on one or two other years.
      Take Care
      Dick
