I am trying to install the ignition shielding on the driver side. When I bought the '69 it had no ignition shields at all. Now I had the exhaust manifold off and installed a new gasket because the old one was leaking. So I thought it is a good idea to install the chrome radio shields I bought some time ago... (before they get old stock). I had already installed the heat shields earlier.
I did expect that the shielding can be removed by unbolting the wing screws and leaving the brackets in place (bolted on with the exhaust manifold bolts). Somehow this does not work for the front shielding (the one with the hole for the temp sensor). The inner heat shield and the outer radio shield cling together and I can not remove the radio shield without unbolting the manifold bolts.
I looked in the AIM for inpiration and in the drawing for the radio shields, there is no inner heat shield for the front driver side. Did cars with radio have no inner shield or was it ommitted in the drawing only? Or is there a trick I have missed?
