While apart for rebuild, it was detected that the harmonic balancer on my 63 FI was coming apart and not spinning true (8" with fins on the inside). It was actually rubbing up against the gunk on the front of the timing cover. IT looks like there is some ring of rubber or something between the hub and the outer balancer. This is all cracking and the outer balancer is wobbling.
I "assume" this cannot be rebuild (or can it) and needs to be replaced. Any source recommendations? Paragon has a repro for $350 (ouch) before discount. Checked eBay and none currently out there. Have seen other "replacements" for $90 but don't know what they look like.
Joe's 63 FI Convertible
