I just found this site and this forum, and just joined the NCRS. This is unfortunate since I have been working on my car for years without really being able to ask others for advice except for sales people. So here is my dilemma: I have disassembled, reconditioned, and partly reassembled the front end of my 67 327 small block car over the last two years (yes, I'm slow). I have new polyurethane conversion kits from Vette Brakes for both front and rear, and the front kit is partially installed. I also have a new thicker front sway bar, rear bar kit (currently none), and new front springs they call 'Grand Touring' springs (rate in between stock and F-41 I understand). The upper and lower A-arms are completely finished and back on the car, so only the sway bar (also a newer thicker bar) is yet to go on. I have not started on the rear yet.
If I knew about this forum earlier I would probably have not used poly parts, as many of you have had bad experiences with them. Mine are supposed to be 'graphite injected'. I talked to as many folks as I knew, talked to folks at Vette shows, and read about them at the time. There appear to be two camps on this: One says they are "too stiff, poor ride, squeak, don't look right", etc. The other camp says "despite what you have heard, they IMPROVE the ride and the newer style poly bushings don't squeak, and never wear out".
I can't return the parts as it has been too long. Should I continue my assembly, or start over with all rubber, or maybe selectively use rubber in some places and poly in others?? Have any of you installed the Vette Brakes kits that include new "balanced" front and rear bars and GT coils springs and if so what was your experience?? My car is planned on being a driver car in mostly original condition. Thank you for your help.
