Help! '58 engine oil pan. - NCRS Discussion Boards
  • Warren F.
    • December 1, 1987
    • 1516
    A new member of NCRS (joined a week ago) ask me to post this.
    He has found an oil pan thats states it came from a '58 'vette. He needs to know if there is only 1 style of pan for all the different h/p rated engines in the Corvette.
    Thanks!
  • Jerry C.
    • November 1, 1995
    • 741
    Re: Help! '58 engine oil pan.
    Only one for all engines. Three step with the oil plug in the front center.
    • Warren F.
      • December 1, 1987
      • 1516
      Jerry:
      Thank you! I will give this message to my friend.
        Drain Plug Is In REAR Center *NM*
        • Ted S.
          • January 1, 1998
          • 747
          Re: Drain Plug Is In REAR Center
          John, Is that true? After reading this string, I noticed in Nolands book that the pic of the FI engine on the buck had the drain in the center front of the sump. It kind of surprised me. I'm hoping its in the rear because if it is I believe I have the right oil pan. If not then I'm looking also.
          • Loren L.
            • April 30, 1976
            • 4104
            Noland's book - pg 222 *NM*
