BEWARE POWDER COATED OIL FILTER CANNISTERS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I installed a powder coated, restored oil filter cannister on my rebuilt '67 engine. (at the cost of $60) It was EXTREMELY tight goint on, but I fugured it would just scrape away the paint as it went on where it wouldn't show anyway, Well, I went to remove it to put the bellhousing inspection cover on and it wouldn't come off. It would rock side to side(with the help of a rubber hammer) but I couldn't pull down on it at all. I tried everything and finally had to ruin it to remove it. I inspected it after I got it off and found the powder coat was extremely thick around the last 1/4" or so at the top where it went into the block.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: BEWARE POWDER COATED OIL FILTER CANNISTERS
    I'd contact the supplier, explain the problem and request a replacement or refund.
    If they do replace, you can relieve the tight fit with a "once around" on a bench grinder until it installs without resistance. Spray a light coat of black paint when done and nobody will know except you.
    thanks for the heads up though,
    tc
    • Clare Carpenter
      Good heads up on the perils of powdercoat! It goes on thicker than liquid spray finishes so masking threaded areas is key but who would have thought the surface tolerances between the block and can would be so tight. Too bad you had to ruin an original part to get it off but just thought I'd mention $60.00 is cheaper than I've seen reconditioned originals. Paragon has them 58-67 for $125.00, all new for $73.00. Both are electrostatic powder paint w/silkscreen and include the gasket and filter. I need one so I'll be sure to check it carefully and not force it on if tight.
      • Craig S.
        • June 30, 1997
        • 2471
        FYI - the paragon parts are thinner wall thickness than the original cans, about half to two thirds the GM can thickness. I am sure this is to simplify the construction.....Craig
        • Rob A.
          • December 1, 1991
          • 2126
          Currently, Paragon has the 141 on sale for $62 and the 131 for $82 till January 9th. I'll be ordering one Monday.
          • Rob A.
            • December 1, 1991
            • 2126
            Craig,
            I thought the Paragon units were reconditioned original, thanks for the info..
            • Clare Carpenter
              Rob, Paragon has the 131 and 141 in both "all new" ($97.00 and $73.00) and in reconditioned originals ($150.00 and $125.00). Haven't compared so I don't know if there's any difference.
              • Jon S.
                • November 1, 1992
                • 202
                Clare,
                The repro does have a thinner wall than originals. The bolt is also unpainted, so it should screw on easily without any powder coat problems. It really is a nice lookin unit. Once on, it looks extremely good and is one-hundred percent reliable. I.ve restored so many originals at the expense of time and money. I now run the repro and have stored all my originals.
                Best regards, Jon
                • Rob A.
                  • December 1, 1991
                  • 2126
                  On sale until January 9, in their Holiday Sale flyer, $62 and $82,(repros) includes cartridge and gasket.
                  • Garry Barnes
                    Rob, Not long ago Paragon would offer a discount to NCRS members if you asked for it. This was not part of any other plan or dependant on how much you buy. I think it was 15% but I don't know if it would apply to items already on sale.
                    Garry
                    • Craig S.
                      • June 30, 1997
                      • 2471
                      I did too, but found out they aren't. Definitely a thinner can. I bought some originals at Carlisle this (er, last) year to recondition myself.....Craig
                      • Rob A.
                        • December 1, 1991
                        • 2126
                        Yes, they give 10% to NCRS members if you ask for it
                        • Jon S.
                          • November 1, 1992
                          • 202
                          Gary,
                          They won't give you both sale price and ncrs discount. But, they will give you the the best price, which ever that may be.
                          Best regards, Jon
