1990 6 speed shifter knob - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    What is the procedure for removing the shifter knob? I need to remove the center console trim plate. I have the service manual, but it isn't very clear. There is a rectangular piece of metal under the shift pattern button referred to as the pin control lever pivot (section 8c-8), but I don't see how to remove it. What am I missing?
    George
    Re: 1990 6 speed shifter knob
    George-----
    You're right----the diagrams and instructions provided in GM Service Manuals just have to be the worst in the world. You need to have a GM Service Manual if you're going to work on your car because it's the best thing available, but it's FAR from perfection. In fact, the other manuals out there (Chilton's, etc.) are even worse because they "borrow" the same diagrams and instructions directly from the GM manuals, but they include way less information, overall. GM should learn a lesson from Honda. Their service manuals are the best I've ever seen.
    Anyway, to remove the knob you first have to remove the shift pattern plate. Then, if I recall correctly, there is a u-shaped "pin" which pulls straight out with a pair of needle-nose pliars. Removing this pin releases the knob.
