In addition to my 1964 Corvette, I also have a 1966 Lemans with with a 1967 Pontiac 400cid engine. Last week, I put an edelbrock manifold and Holley carb on the Lemans.
I now have the following problems:
- at start up, while the choke is on and the engine cold - it has a strong idle and then starts to die and then stalls. Vacuum reading is about 15. It does have an aggressive cam.
- once it warms up, it stays running and the vacuum reading is steady at 17. The timing is correct and it drives well, however, it occasionally backfires through the carb on mild acceleration from a coast.
I really only know enough about engines to get myself in trouble, therfore, my question is - does this sound like a vacuum leak?? I've sprayed all around the manifold and carb with carb cleaner to try to detect a vacuum leak by the rpm change but have not been able to detect anything. Any help would be appreciated...
Ed
Ed
