1967 Fan Shroud & Radiator Support - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    Need help with finishes.
    What is the correct finish for a 1967 fiberglass fan shroud? Should it be painted or natural? If painted what color and finish?
    Also, what color and finish should the radiator support be? Should it be semi-flat black, semi-gloss or what?
    Ralph #37280
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1967 Fan Shroud & Radiator Support
    SB Rad shroud is natural
    BB Rad shroud is black
    support on either is semi gloss black
    • Wayne W.
      • April 30, 1982
      • 3605
      Well, not exactly. If that support is on an AOS car, you are going to see a lot of green zink chromate, and black on those surfaces that were hit with the blackout process. That process typically was not too thorough. Most AOS sheet metal parts were finished in zinc chromate. The blackout process seldom got it all covered.
      • Ralph E.
        • February 1, 2002
        • 905
        Thanks. I have a AOS car with the green zinc showing through. The blackout is heavy in places. It looks bad. My plan is to strip the old paint and repaint entire core support. I was going to paint the shroud. Now I'm re-thinking it. I had to remove a lot of overspray and undercoating that was on the shroud. It looks clean but a little ratty(spl?)
        Ralph
