My '66 L-72 has a Delco restoration battery that I believe to be a few years old. My problem is the battery cell closest to the exhaust manifold is constantly leaking battery acid. The cell is not over filled and the charging system appears to be fine. Can someone perhaps tell me why it always leaks acid. The only thing I could think of that the exhaust manifold is causing the battery fluid to heat and expand causing the spill.
The battery holds it's charge well and has always started the car, etc. But I'm tried of always cleaning the acid to prevent damage.
Also, can anyone tell me which new Delco maintainence free battery will fit to use as an replacememt. I think I'll retire the restoration battery for judging.
Thanks all.
Kurt Neiman
Thanks all.
Kurt Neiman
