C-3 Steering Column - NCRS Discussion Boards
C-3 Steering Column
  • Michael C.
    • May 31, 2003
    • 72
    C-3 Steering Column
    I have an extra tilt/tele column for a 76. What are the design commonalities with the prior years columns? Can a 76 column be used in a 75 by changing the hub, etc. for use with the older style wheel? Thanks.
    Re: C-3 Steering Column
    T-Tele column is basically the same '69-76 with differences in 'dress' unique to certain model years (TS lever, e-flasher button, horn ring emblem, Etc.).
    • Michael C.
      • May 31, 2003
      • 72
      Jack, thanks for your respsonse. If I read you correctly you believe it is possible to make the 76 column suitable for an older model, say a 75, by changing out the bell, hub, lock ring, etc?
