C-1 Spark Plugs - NCRS Discussion Boards
C-1 Spark Plugs
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 Spark Plugs
    Just built a 59 270HP engine with Keith Black 10.5 dome pistons and nedd to know what spark plug to use. This will be a judged car so I should stay with AC plugs. Any help, please. Thank You
  • Dave S.
    • August 31, 1992
    • 2918
    Re: C-1 Spark Plugs
    Jerry,
    The detectable lack of AC plugs will be cause for a deduction on the judging field. I would recommend using an AC 44 or 45 plug. You also need to decide if you want to go the 4 equal ring (earlier) style or the 3 equal and 1 unequal ring (later). Actually in 1959 the original AC plugs had no green rings. Green rings were introduced on AC spark plugs around 1961, but the earlier no green ring style are rarely seen.
    • Norbert R.
      • March 1, 2002
      • 38
      Re: C-1 Spark Plugs
      There is a set of 44s on Ebay now...green rings
