The automatic choke on my 1964 327/300 is not opening after the engine reaches operating temperature. I am thinking that either insufficient vacuum pressure or too much resistance between the choke piston and cylinder (or both) are preventing the choke from opening properly.
I recently unfroze/degunked the choke piston after it had been frozen in place for who knows how long (frozen when I bought the car). After removing the choke piston and thoroughly cleaning the piston and cylinder bore, I still encounter a fair amount of resistance when manually moving the piston up and down in the bore. I liberally applied sealant to the bottom of the cylinder bore on and around the cap at the bottom thereof. I also made sure that the O-ring between the choke assembly and carb is in place.
Does anyone know how tightly the choke piston should fit in the cylinder? I am tempted to attack the cylinder bore and/or piston with some emery cloth to produce a looser fit, but worry that I may lose all vacuum pressure if a tighter fit is called for.
Any advice or insights would be GREATLY appreciated!
