Re: A little gas trivia
Yes, just to review for everyone the "octane rating" of a fuel is its detonation resistance compared to a blend of iso-octane and normal heptane. A fuel that exhibits the same knock resistance as a blend of 80 percent iso-octane and 20 percent normal heptane is rated "80 octane". Once you find a blend that is more resistant to detonation than 100 percent iso-octane, it is compared to 100 percent iso-octane with a specified quantity of TEL per gallon. I can't remember the details but 101 octane would be equivalent to 1 cc/gal or, 102 to 2 cc/gal - something like that. Above the 100 octane level the scale is highly non linear.
Add to the confusion that there are two test methodologies for automotive use, Motor Method and Research Method. The Motor Method is more severe and is most applicable to high load applications such as trucks and race cars. The Reseach method is less severe and probably more applicable to typical passenger car use..
When EPA proposed the all pumps be posted with an octane number, they couldn't decide which to use. In the sixties, gas stations that displayed octane number used the RON. EPA decided to used the arithmetic average, and the difference between RON and MON averages about 8-10, so you add 4-5 to compare today's PON to the sixties RON.
Aircraft octane rating is measured using different methods that were develoed in the thirties and forties as aircraft engine performance increased and high boost became common. The dual rating (like 100/130 and 115/145) applied to low boost lean mixtures/high boost rich mixtures. Modern avgas has gone back to single ratings since few high boost reciprocating engines are still in service, but the aircraft rating system is more severe and is probably most comparable to MON (but not exactly the same), since aricraft engines normally operate at high load.
