This problem really has me stumped. My 1964 327/300 with a Carter AFB and PG hesitates/stumbles noticeably while accelerating from a dead stop. I have to "feather" the pedal to keep from the engine from stalling. Once I'm rolling I can put the hammer down with no problems--only at a dead stop do I have to tease the throttle. The problem is less severe after the engine warms up, but not appreciably different. Needless to say, not being able to take off strong from the hole is a big buzz kill.
I have eliminated all of the usual suspects having replaced the plugs, wires, points, rotor, distributor cap, etc. I completely rebuilt the carburetor making sure that the float settings were accurate. I also made sure the pump lever was adjusted properly (1/2" from the air horn). The problem was much less severe after I rebuilt the carb, probably because the pump diaphram was dried out and the float settings were wrong. I see no smoke after the engine "catches" so I suspect my problem is not due to an overich situation.
I'm thinking the problem is related to the carburetor, but I do not know what to try next. I would really appreciate any advice on where to go from here.
