1954 Corvette Radio Wiring and Emergency Brake - NCRS Discussion Boards
  • Bill Orr
    Does anyone have or know where I can get an underdash wiring diagram for the 1954 Corvette Radio and the Emergency Brake Flasher? I'm trying to find out how to connect the wiring from the radio to the dash connections and also how to connect the emergency brake flasher.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1954 Corvette Radio Wiring and Emergency Brake
    Radio hot line goes to the fuse block and the brake flasher unit hot line. The fuse block is marked radio. They get hot when you turn the key on.
    • Bernard M.
      • August 31, 1994
      • 341
      There are good descriptions of the wiring and routing in the 56-57 assembly manual. The e-brake flasher switch and wiring is the same, only the bulb and flasher are different (6v vs 12v). I would think that the radio wiring should also be similar.
