I have a question regarding the conversion of a 427 2-bolt main block to
a 4-bolt main block. As most of you probably know, the availability of
427 4-bolt blocks is quite scarce. When one does appear ( ebay usually )
it commands big bucks! However, most 4-bolt main blocks have been used
hard and as such usually have larger overbores. I don't like that.
Over the last year, I have run across a few 427 2-bolt main blocks with
standard bores. I like that! The challenge now is to determine if a 2-bolt
main block can be converted into 4-bolt main block. Now, I'm not asking
about the mains. That is an easy modification. I'm referring to the oil
plumbing fittings on the left side of the engine ( over the oil filter boss ).
One member of this forum was very kind to assist me while determining the
viability of particular blocks for this purpose.
So the question stands in regards to this oil plumbing. Have any members
gone through the pain & expense to have the oil plumbing modified ( drilled )
to reflect a factory 4-bolt main block? I didn't think it would be that
difficult, but after purchasing a 2-bolt main block, I now find that the
machine shops interested in the project are now concerned about ruining the
block. I would assume that these holes need to be gun-drilled. Can anyone
recommend a machine shop that can handle this modification? I'm in North
Carolina, but that isn't as big a deal as getting the machining done properly.
I would greatly appreciate any and all recommendations.
Steve
Steve
