1963 coil spring - NCRS Discussion Boards
1963 coil spring
  • Timothy B.
    • April 30, 1983
    • 5177
    1963 coil spring
    My car seems to be sitting lower than normal in the front and after measuring the ride height acording to the 63 shop manual it seems as if I have bad coil springs. Is there a supplier someone can recommend that correctly reproduces these springs? Thanks in advance, Tim Barbieri
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1963 coil spring
    Congratulations on being a NCRS member since 1983, that is a long time. You might be able to find springs for your 63 from www.eatonsprings.com. There web page advertises they have been making springs since 1937. I believe your 63 did not use the progressive rate spring like later years.
