1969 Transmision Vacuum line - NCRS Discussion Boards
  • Kelly Burnside
    Does anyone know where I can get a 1969 auto transmision modulator vacuum line? The assembly manual shows it as part number 3925693. Mine was cut on the end and the mounting tab has broken off. I may end up going to Right Stuff to see if they can make one if there is none available. All resources show them for 70's big block. I need one for a small block car.
    Re: 1969 Transmision Vacuum line
    Check out the Dr. Rebuild catalog. They list everything for AT vac (modulator valve, interconnect hoses, steel vac line, and clips).
    • Kelly Burnside
      Dr. Rebuild appears to not have a prebent line with the clip unfortunately. They do list a line that is not prebent and with my luck I would bend it and end up crimping it!!! There is one other place that may have it. Thanks for the help
      • Roy B.
        • February 1, 1975
        • 7044
        Most cars in the 70's with the 400, and big block engine will have the same line. Have you tried a wrecking yard?
