battery shut off switch - NCRS Discussion Boards
  • Jim D.
    Infrequent User
    • December 1, 2003
    • 12
    can i use a battery "shut off"switch in my 98 pace car without affecting the electronics?
  • Tom Freeman
    Re: battery shut off switch
    You would loose any "memory" setting with a break in the electric flow. Things like power seat memory, radio setting, etc. You can get a 9 volt plugin for the cig lighter to maintain the setting but not sure how long that will last. They also make disconnect switches that will allow a very small amount of current flow to keep the setting live.
    One big problem with a battery disconnect switch on late models is that you loose your security system with the battery disconnected.
    tom...
      • 11608
      Jim,
      FYI, many find the "green knob" type have more problems than the "guillotine" type. A friend had chronic problems with his 1990 ZR-1 not starting (as if he had a VATS problem) until he removed his green knob.
      I have used the Sav-T-Switch (spelling?) as advertised in the Driveline with good results. They give a discount to NCRS members.
      Patrick
      • Ed Jennings
        The green knob switches work fine, but you have to tighten them securely. No wrench or anything like that, but they need a good solid twist by hand. If tightened "gently" they can make poor contact.
        • Joe C.
          • August 31, 1999
          • 4598
          NO! *NM*
          • Joe C.
            • August 31, 1999
            • 4598
            More>>>>>
            not only will you lose your clock, and radio station settings, but it will also give your PCM a frontal lobotomy.
            • Larry Parylla #41143
              Re: More>>>>>
              I was going to say the same thing as Joe 32899. The C5s suck the power out of a batter faster than any car have ever owned. I used a battery tender on mine. They cost a bit more than the $9.99 cheapo ones but the cheap ones will ruin your battery by over charging. This explains why the Battery tender is the best
              Eastwood sells them for $59.99 and puts then on sale from time to time for ~$45 to $50 if you shop around you may find them even cheaper. They are worth the extra money, I own 4 of them. Here is the eastwood search link, just type in battery tender
                • 11608
                Re: More>>>>>
                I prefer the Battery Minder (www.vdcelectronics.com) but they're very similar.
                I think the best solution for a C5 is to drive it regularly during the summer and avoid the problem. I then disconnect the battery during the winter, but hit the battery with the Battery Minder in the spring before I reconnect.
                Patrick
                    • 11608
                    Re: More>>>>>
                    Larry,
                    Just type in "Battery Minder" in your browser and pull up a boatload of stuff. It has the same circuitry or better as the Battery Tender. I bought mine from Restoration Battery at their Carlisle display.
                    Disconnecting the battery ONLY erases the flash memory of your computer. It just means it has to "re-learn" the parameters of your particular motor. Not a big deal at all if done once a year. In fact, if you make any motor or performance modifications, you should disconnect the battery so that it learns your new configuration faster.
                    Patrick
                      Re: More>>>>>
                      I think I may have found it,
                      From what I have read about it it may be better. Since I own 4 Battery tenders I will stick with what I have. I have been using them for years and am very happy with them. If I needed a new one I would take a very close look at the one you suggested.
