Removal of upper pulley 1965 - NCRS Discussion Boards
  • Rick Hendel
    I'm trying to freshen up and paint my engine and water pump. My question is I have taken off my fan clutch and fan and I'm down to the pulley. If I remove the center nut on the pulley should the pulley slip off easily or do I have remove anything else to expose the water pump so I can paint it. Thanks for your help.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Removal of upper pulley 1965
    Center nut on a water pump pully?
    • Jack W.
      • August 31, 2000
      • 358
      center nut? we don't have no stinkin center nuts on our water pump pulleys (sorry, couldn't resist) . . . there is a centering nodule, of sorts, but the thing is held on by four bolts (or is it studs and nuts?) . . . big ol' thing in the center of that pulley on the bottom, however . . .
      • Joe C.
        • August 31, 1999
        • 4598
        Nuts? No, Just A Lug And 4 Bolts *NM*
        • William V.
          • December 1, 1988
          • 399
          I can give advise on the nut that holds the wheel but I know nothing of a center nut holding the water pump pully
