I'm ready to paint my 64 convertible and have noticed that the body seams (where the panels are joined by bonding strips) become noticeable to the touch (barely noticeable to the trained finger of the painter (myself) ) when the panels are subject to a hot soak in the sun. I've painted Corvettes before and not noticed this. What I'm feeling is a slight dip (a few mills deep) where the seam is, when the panel is warm. When the panel cools in the shade the dip goes away.
The car was stripped to bare glass with chemical stripper (in small sections) , properly washed down with water and MEK immediately following stripping, recoated with red oxide polyester primer, boarded out to a 280 grit finish, and then primed with Dupont Uro Prime and blocked with 600, in preparation for the top coats.
While the prep looks great, I'm still concerned about the phenomenon that is occurring at the body seams. While it doesn't seem noticeable to the eye, it is in fact occurring.
Has anyone else noticed this? Is this normal? I know that some one out there can answer these questions for me. I don't want to shoot the top coats until I've figured out if I should be concerned or not.
I know that the seams on original cars can be noticeable. My car had one enamel repaint on top of the original lacquer paint, and the seams for the most part were all noticeable. However, I was under the impression that it was due to the paint materials shrinking over the years and the cold flow of the polyester panels.
Any advise regarding this matter will be greatly appreciated.
Thanks, Phil
Thanks, Phil
