I would appreciate some advice on how to correct the door fit on my 67 SB roadster. On both the driver and passenger doors the gap between the rear edge of the door and the rear body is nearly zero (at top of door) when car is sitting with all tires on the ground. I have checked and replaced the door hinge pins and bushings which corrected the previous interference fit but has not restored the desired 1/8" gap. The gap at the leading edge of the door is uniform and is about 1/8", so moving door forward on hinges is not a good option. I have noticed that when I put the car on the lift (lift on frame rail behind front wheel and just in front of rear wheel) the rear door gap opens up to a very nice uniform 1/8" gap. I have throughly inspected the frame and found no weakness or even significant rust in the frame rails or kick up junction. My current idea on the casue is the #3 rubber body mounts are compressed which might allow the body to hinge at that mount. I am considering tring to replace this mount (with minimal lift (>1/4") of body and insertion of new rubber mount.
Has anyone else experienced a similar door fit problem and solved it?? Is it possible that the #3 mount could really be the cause? Can the mount be replace with the minimal lift I am considering?
