C2 emergency brake - NCRS Discussion Boards
C2 emergency brake
  • frank mccracken
    C2 emergency brake
    Working on my '65 roadster I was able to somehow dis-attach my rear most emergency brake shoe hold down spring on the driver side. With the wheel spindle in place this is gonna be a job for small long fingers. The worst part is that you can't hold that pin in place from the back of the backing plate. Anyone have any tricks?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 emergency brake
    where you're going is doable without pulling the spindle. i've always wished for a tiney oriental with long and dexterious fingers but alas it just requires patience.good luck, mike
    • frank mccracken
      Thanks Mike,
      At this point I'm following the instuctions from this site.
      Now I'm waitin' for the silicone holding the pin to set over nite. I have a feeling that I'm going to want it set up as much as possible. Got the heat gun on low on the silicone now to get it happening.
      • Tracy C.
        • July 31, 2003
        • 2739
        Gee Doc... why not just use Hemostats?? *NM*
        • frank mccracken
          I don't understand the above statement but..
          anyway, I got 'er done using the dental floss and silicone! Tough little job.
          • Tracy C.
            • July 31, 2003
            • 2739
            Re: I don't understand the above statement but..
            Frank,
            Hemostats are used by Doctors during surgery for a number of things (to clamp off arteries, sew up opened wounds etc..)There are a number of sizes and shapes for different applications.
            Think of them as a cross between needle nose pliers and vise grips.
            I learned of their potential as a tool in the industry during a electronics class where we used them to secure small resistors and relays onto circuit boards as we soddered them in place.
            I have a pair in my tool box and have used them to retrieve dropped screws in distributors and reach into tight spots to place small washers or clamp and hold things when I want them to stay until I can get the nut on.
            This seemed like a good opportunity for them as well.
            tc
            • frank mccracken
              Maybe I should check into them!
              • Bruce Boatner
                I recall a different use for "hemos" when I was in college. Thanks for sharing the intended uses--I always wondered.
