Rad support bracket on a 67 SB - do they exist? - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    I am confused and hoping that one of you with a 67 SB car might be able to help. I have been working on my front and have had the rad support, shroud, and radiator off the car. While researching parts I noticed that my car doesn't have the little brackets on the lower front end that attach to the same bolts as the two support rods that go from the lower rad support to the underside of the headlight area. My 67 assembly manual shows them, but I don't see how they would possibly fit as the manual shows. I noticed in photos in my copy of Noland Adams book that 63-65's seemed to have these brackets as they can be seen in photos of the underside of the car. There is a small screw that goes through the fiberglass of the lower front end into these small brackets. Basically, is my car supposed to have these little brackets, and if so, how and where do they mount???
    Thanks!
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Rad support bracket on a 67 SB - do they exist
    Yes, your car is supposed to have them. They go between the long bolt and the headlight rod. 63-65 have them, but are mounted farther back. Since the support is mounted at a higher angle in the 66-67, the bracket hits the lower panel farther forward and the screw is forward. The screw goes through the lower panel to the bracket and is painted with the body.
