Painting Shop/Garage Floor. (suggestions?) - NCRS Discussion Boards
    • 11608
    Re: Enough about flooring
    Don't send them - POST them!
    Patrick
    • Mark H.
      • July 31, 1998
      • 384
      heater
      What kind of heater do you have hanging from the celing?
      • Kent K.
        • December 1, 1982
        • 1139
        #18
        Re: Epoxy Checkerboard Shop/Garage Floor
        Hey this is great information!!! My garage/shop is under construction and I am considering using epoxy for the floors in a black & white checkerboard pattern. Obviously, slab preperation is the key for all epoxy floor coatings. Does anyone have experience with the pattern application?
        Thanks, Kent #6201
        Kent
        NCM Founder - Member #718
        • Clare Carpenter
          #19
          Given how epoxy is mixed and applied, I would think it would be difficult, if not impossible, to obtain the desired results. I can't remember seeing an epoxy floor in something other than a solid color, or with some flecks added. Tile might be a better choice for a checkerboard floor pattern. If a tile were to get damaged you could easily replace it.
          • Dick W.
            • 10483
            #20
            Re: Painting Shop/Garage Floor. (suggestions?)
            I have used system by Ameron. Epoxy and urethane combination. Has been down 5 years in my shop with NO peeling or lifting. If anyone is interested I can get the product numbers
            Dick Whittington
            • Sydney G.
              • February 1, 1994
              • 443
              #21
              Right on Dick. I should have mentioned the combo option in my previous thread. Again, preparation of the sub strata is the key here. Do not contaminate the exposed pores of concrete and make sure to cure. Also, ask for a good 4" border or cove. It will be like a bathtub after.
              Now back to Corvettes......................................... .................
              Syd
