1958 Carb - NCRS Discussion Boards
1958 Carb
  • sherm rhymers
    1958 Carb
    I need a "choke spring cover" for my 1958 carter wcfb carb. It's just the black plastic cover on the side of the carb with the connector for the tube that goes into the exhaust manifold. can anyone help? Thanks
  • Terry D.
    • May 31, 1987
    • 2690
    Re: 1958 Carb
    Sherm
    If your looking for original, check with Mary Jo, Grossmueller's or Paragon to see if they have a used one. Corvette Central sells new ones, but not sure of their originallity, someone else may be able to tell you that.
    • Mike M.
      • May 31, 1974
      • 8365
      Re: 1958 Carb
      Gary Hodges, page 3 of Restorer and the carbg tech expert, usually has originals at reasonable prices. He's a good guy also. mike
        Re: 1958 Carb
        Chicago Corvette, Cat No. A3709, Used/Original Carter choke cover, 57-62 WCFB & 62 AFB...$39.95
        • sherm rhymers
          Re: 1958 Carb
          Thanks to all of you
