I've reviewed the archives posts on this subject and did not see this issue addressed. The under dash courtesy lights on my '64 convertible "work" in that they trun off when the plunger button is depressed and they light up when it is released. Unfortunately, the door hinge won't push the plunger in enough to turn them off. Is there an adjustment that can be made to the switch internally? (Nothing obvious here on inspection) The only other option I can think of is a washer or two on the switch to build it out far enough for the door to depress it.
Additionally, I can't find the rear compartment light at all. Where is it supposed to be? Where is the switch? How is the wiring harness routed?
Thanks.
Mark Hedberg
Thanks.
Mark Hedberg
