coil wiring - NCRS Discussion Boards
coil wiring
  • Jim K.
    • November 1, 1995
    • 84
    coil wiring
    I have a 71 454. I need to know the proper wiring for the ignition coil. There is a black wire from the distrbutor and I think it goes to the negative terminal of the coil. There are 2 white wires from the battery that go to the positive. And there is a small condenser that should be connected to the positive. Is this correct? Thanks, Jim
    Re: coil wiring
    Jim-----
    Your hypothesis is correct.
