Suspension/Drive Joint Greases - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    Will I have an issue if I load my front suspension and universal joints with synthetic grease?
    Will the synthetic grease properly co-mingle with the greases loaded into them from the manufacturers?
    Thanks for any feed back,
    Chuck
    Re: Suspension/Drive Joint Greases
    Chuck----
    If the base of the greases is the same, I don't think that there will be any problem. Most conventional chassis greases are lithium based, but some are aluminum or other things. In a chassis fitting situation (like ball joints, tie rod ends, other steering parts, etc.), the application is a decidely low speed application. So, grease incompatibility shouldn't be much of a problem, anyway.
    Notwithstanding the above, I wouldn't use the synthetic grease for the sort of chassis applications that you're contemplating. It's not necessary and I can't see any benefit, other than convenience if you have only one "loaded" grease gun. I recommend and use only GM #12377985. I keep one grease gun loaded with it for all chassis applications. This is a high quality, lithium-based conventional chassis lubricant.
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Even 12377985 for U-joints? *NM*
        Chuck----
        Yes, that's the only one that I use for u-joints, too.
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Thanks Joe
          As alway, I appreciate your input.
          Chuck
