This is not an NCRS question but I'm wondering if any '60-'62 owners have or had a set of Traction Master traction bars installed and whether the swaybar was left in place.
My '62 came with a set of Traction Master traction bars installed. I'm trying to determine whether the installation was as recommended by TM, or whether these bars are for an earlier C1, with the installation user-modified to clear the rear sway bar brackets.
In the rear bracket there is a set of 4 tubular spacers between the spring plate and the rear traction bar bracket to allow for the sway bar bracket to clear. The u-bolts are longer than stock and pass thru the spacers before bolting up in the normal fashion.
I don't know whether TM made a special rear bracket for the '62 to allow for sway bar clearance, or if they recommended removing the swaybar prior to installation. The installation I described above may be a "factory" recommendation or user modified, either way they worked well eliminating any wheel hop and improving braking too. I plan to reinstall them on my car as a "period correct" piece. I am sending my components out to TMC for new bushings and associated hardware. It will be interesting to see what they have to say, as the TM bars for C1's have been out of production for many years.
Here's a link showing pictures of John Hinckley's '57 with Traction Masters installed. Of course, the '57's didn't have a swaybar.
http://forums.corvetteforum.com/zerothread?id=171385
