'67 Steering Damper part numbers? - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    I'm pretty sure that my '67 327/350HP Non-power steering car should have a "steering damper" installed on it. Does anyone know the GM part numbers for these items?
    1) the damper.
    2) the bracket that mounts to the frame.
    3) the bracket that mount to the relay rod. (is this bracket flat, or does it have a 90 degree bend too it?)
    4) and the two bolt plates the help mount the bracket to the frame.
    Does anyone have these? Used are O.K.
    Thanks Ken
    Re: '67 Steering Damper part numbers?
    Ken-----
    Yes, your car as described should have been equipped with the steering shock absorber (damper). The parts are as follows:
    shock absorber------GM #22011964 (currently available replacement for original GM #3178100)
    relay rod bracket---GM #3830243----discontinued
    frame bracket-------GM #3830242----discontinued
    frame reinforcements-GM #14011278 (currently available replacement for original GM #3832132)
    I believe that the discontinued items are available in reproduction from sources like Dr. Rebuild and Paragon. In fact, all of the above-referenced parts should be available from them.
    The relay rod-mounted bracket is NOT flat; it has several bends/offsets.
