'67 NON-RUBBER COATED WIRE CLIPS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I need a couple of the steel(with no rubber coating) clips that are rivetted to the body in several places, such as guiding the speedometer and hood latch cables. Long Island doesn't carry them, and insists they were never used, and although Paragon shows it in their catalog, they only have the rubber coated ones as well.
  • Dave K.
    • November 1, 1999
    • 951
    Re: '67 NON-RUBBER COATED WIRE CLIPS
    Remove the rubber. Use a grinding tool or knife to remove the rubber. It comes off easily. I did this for clips used on my 66 firewall.
    Dave Kitch
    • Mike M.
      • September 30, 1999
      • 710
      My 65 firewall clips had a rubber coating
      The only clips that didn't have a coating were the headlight harness clips. I think these clips were orignal to the car. Was 65 different or do I have this wrong. Judging guide dosen't say, just says metal J clips. Mike
      • Dave K.
        • November 1, 1999
        • 951
        Re: My 65 firewall clips had a rubber coating
        My 66 the same.
        Dave Kitch
        33108
        • Kent K.
          • December 1, 1982
          • 1139
          Rob,
          My '67 hass a middle-of-the-production-year AO Smith body with two clips riveted to the firewall for guiding the hood release connector cable and some other wiring harness. These clips were not rubber coated but were painted during the "blackout" procedure. FWIW - Saint Louis body Corvettes and other mid-year Corvettes as well as early or late '67s may have been different. This is simply offered as one example. Have you checked the judging manual?
          Kent #6201
          Kent
          NCM Founder - Member #718
