Below is a pick of my Strut Rod bracket. As you can see, there are two very thin metal squares on the bottom on each end. They were pretty bent up but I was able to straigten them. They are however a little cracked where they are welded. No surprise, it's a pretty chintzy setup.
Before I weld these, is this correct? I doubt someone would add something like this later on but I have not seen them before. Personally I would rather just remove them. But in doing so, would that cause a point loss in a judging event assuming they are factory?
Joe..
Joe's 63 FI Convertible
Joe..
