Vacuum Advance and Vacuum Gauge - NCRS Discussion Boards
  • Donald M.
    • December 1, 1984
    • 498
    Sounds like a basic question, but, is it OK to use the vacuum advance line/connection as a source of vacuum for a vacuum gauge? The gauge hose would be "tee'd" into the advance line to preserve the idle advance.
  • Ed Jennings
    Re: Vacuum Advance and Vacuum Gauge
    It depenmds on whether your vacuum advance line is seeing full manifold vacuum or "ported' vacuum. If it's full vacuum, there's no reason you can't tap into this line.
    • Donald M.
      • December 1, 1984
      • 498
      Ed, I should have mentioned that I have a 67 327/300,non-smog car.So,it is definately full vacuum. Thanks for the help. Don
