I have gone through the three carbs four times now. I have replaced new gaskets with new gaskets, tightened and retightened screws, bolts and nuts. Checked bolt length for proper length and still I get a gas leak on the manifold under the float bowl on the center and rear carb. It only happens when the car sits for several hours. While running and I must say the car runs absolutley perfect there is no leak inside or out and while idling both out board carbs are dry on the inside. I noticed on the flange where the gasket butts up to on the float housing on the bottom there is a small hole that seems to vent back into the float bowl when I blow on it. What is that and should it be there?
PLEASE help me I am about to lose it
