67 Plug Shield Bracket Color? - NCRS Discussion Boards
  • Scott Landis
    In restoring the ignition shielding on my 67 327/350, the plug shield brackets (all 8) were a bit rusty, but cleaned up pretty well. Is there a color they could/should be painted to preserve them in the future? Or should I leave them to rust again? I don't remember them as showing much before, but I want them to be right. Scott
  • Bill Clupper
    Re: 67 Plug Shield Bracket Color?
    Your choice of Cad, (very Likely) Zinc (possible) or Tin platings, all are to some degree a bright, silvery finish. In the Mid-60's Cadmium was commonly used. Not generally used today due to health hazards in Plating Processes.
    • Bill Clupper
      • Scott Landis
        Thanks Bil, for your help. I just painted my thermostat housing (aluminum intake manifold) with Alumiblast silver. Would this color be appropriate for the brackets?
        • Scott Landis
          • Carl R.
            • March 1, 1998
            • 166
            Hi Mr. Landis!
            The plug shield supports (that bolt to the exhaust manifold) will rust again if you use the car, regardless of what you paint/plate with. As shall the bolts/washers; I used to paint mine with a VHT high-temp clear coating - which seemed to postpone the inevitable slightly - but left a different texture & slightly to shiny finish. If you are planning on showing the car, you shall probably need to replate (I seem to remember some little detail - a stmaping? - on the reproductions that is not the same as factory). If not showing, Paragon used to manufacture these brackets in stainless steel specifically to combat this problem.
            Carl
            • Carl R.
              • March 1, 1998
              • 166
              Hi Mr. Landis!
              Carl
