58 oil breather
  • kenneth bingener NCRS#38563
    #1
    58 oil breather
    Trying to get the oil breather tube out of the aluminum intake. Did the PB Blaster soak for over a week with no result. Tried a channel lock with a rag around the breather. Can I heat this up? If so do I heat the tube or the aluminum (gingerly)? How about a heat gun? Any help appreciated. Want to try to save the tube and not harm it in the removal process. Thanks, Ken
    • 42936
    Re: 58 oil breather
    Ken-----
    Is the manifold on or off the engine? If it's off the engine, I'd try to press it out from the rear with an hydraulic or arbor press. You'll need to set the manifold up properly on the press and ensure that the area around the tube is fully supported befoire pressing.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Re: 58 oil breather
      Ken - Why do want to remove it? This could be one of those missions that causes more problems than it solves. Dennis
        Re: 58 oil breather
        Just did that last week for an intake swap - I used a piece of fat broomstick in the tube, reefed it back and forth, and it loosened up in about 30 seconds. It's a press fit - they stuck a bearing driver-type tool in the top of the tube and whacked it with a hammer.
