(Message Deleted by Poster) - NCRS Discussion Boards
  • Ken Kosanda
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: PVC "T" fitting
    Ken, you can get the tee from Dr. Rebuild...the bad news is you will have to buy the entire PCV/evaporative canister hose kit ($40) to get it. From the catalog, it appears that the tee is not sold separately. If this is for function only, I believe I would mosey on down to Home Depot to see if a rigid tee fitting used for flexible butyl tubing might not work.
      Re: PVC "T" fitting
      Ken-----
      The piece you seek was GM #3970076. It was discontinued about a year ago, but I'll bet that there are still some "around".
      Also, this is a piece that was not used just for 1972 Corvettes with LT-1; it was used on many other Chevrolets of the period, as well. I'll bet that one could "turn one up" pretty easily at a self-serve salvage yard.
      • Ken Kosanda
        Re: PVC "T" fitting
        THANKS FOR YOUR HELP. I ORDERED A FULL KIT AND IT IS ON THE WAY . KEN
        • Ken Kosanda
          Re: PVC "T" fitting
          I ORDERED ONE FROM DR. REBUILD. THANKS FOR YOUR HELP. KEN
