HAve a friend with an early built 61 315hp car. The voltage regulator died and he was going to send the "original" off to be rebuilt. Now, I don't think the regulator on the car actually is the original. My references indicate a number of 9001 D on a 60-62. His regulator is a 9002. Am I correct? I suspect the regulator was changed years ago. This guy has owned the car for 20 years or so, but the car is 43 years old and had 20+ years to get a new regulator before he bought it.
61 voltage regulator
Re: 61 voltage regulator
Ed
According to Judging manual:
1961 9001D All exc. 315hp 30 amp
1961 9002D 1st design 315hp-4 1/8 pully 35 amp
1961 9002D 2nd design 315hp 4 1/8 pully 35 amp
1962 9002E 250 & 300hp 3 5/8 pully 35 amp
1962 9002E 340 & 360hp 4 1/8 pully 35 amp
Hope this helps
Terry- Top
Ed,
On a stamped date code(as opposed to) a cast date code the I is not used. That allows the use of M on stamped dates for the month of December. K is November on a cast date but is October on a stamped date. You could use anything dated between April and September applying the 6 month rule and if the car is a mid to late October build you could use an October dated regulator.- Top
