HELP -- ROY BRATZ OR WHOEVER - NCRS Discussion Boards
  • Don S.
    • February 1, 2000
    • 476
    It appears that the gas level sending unit in my 55 vette is kaput. (Wrong readings). I thought I read somewhere that you could use a 55 truck or car sender. Obviously originality is not an issue as you can't see it. What is the best fix for this problem and where can I purchase a unit. Thanks
  • Ed Jennings
    Re: HELP -- ROY BRATZ OR WHOEVER
    Well, I'm sure no 55 expert, but there are some some things that can be repaired on your sender. If the gauge consistantly reads too high or low, you can bend the float to get it closer. The gauge will give a faulty reading if the sender is not grounded real well. I assume the sender is different from the 56-62 sender? If your car is a 12V model, can a 56-62 sender be adapted? I dunno, just asking.
    • Roy B.
      • February 1, 1975
      • 7044
      How about this
      • Don S.
        • February 1, 2000
        • 476
        Thanks guys.--Dont know about same as 56 but maybe I can get a truck sender for 53 or 4 at Napa.
        • Dave Suesz
          I have truck gauge and sender...
          About 20 years ago my gauge and sender went up in smoke, so I pulled the sender and gauge guts out of a 50-something Chevy truck. The only difference was the rheostat insude the sender. The truck rheostat is the same from full to empty, but the Vette sender rheostat was tapered at the bottom. This is because the Vette tank is tapered at the bottom. Everything works perfectly now, except the last 1/4 on the gauge is really about 1/8, so I have to be a little careful on road trips.
          • Roy B.
            • February 1, 1975
            • 7044
            53 to 55 sender won't work for 56-57. 53 to 55 fuel tank gas line is located on the bottom R/S./
            56 up gas tank gas line comes out at the sender.
            They are two different gas tanks.
