radiator for a 57 - NCRS Discussion Boards
radiator for a 57
  • dennis frey
    radiator for a 57
    been thinking about swapping out old orig radiator for aluminum. corvette central carries a griffin repro. has anybody had experience w/ this? does it pass for looks? worth the big bucks? or are there better cheaper? etc. thanks in advance. dennis.
    Re: radiator for a 57
    No, the Griffin radiator won't pass judging without deductions. DeWitt's has two options you might consider - a correct new restoration core any good radiator shop can use with your existing tanks, or a new direct-fit aluminum reproduction that looks just like the original (when painted black) but has twice the cooling capacity of the original.
    • Art B.
      • 333
      Dennis:
      As John stated, I had a local radiator shop replace my '57 radiator core using my original tanks. The price was far less than a new reproduction and it works great. It also passed flight judging without a problem.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        I spent about 3 bazillion miles driving a '57 with a bone stock original radiator and never had a heating problem. Maybe, just maybe, you are trying to fix a problem that dosen't exist. ??? Best, Dennis
        • Art B.
          • 333
          Dennis:
          In my case, it was a problem. My '57 overheated often when driving low speeds such as in parades. When I replaced the core, my overheating problems went away. I can only assume the radiator core was plugged. The radiator shop owner concurred that it was indeed plugged with corrosion.
          • dennis frey
            thanks art and all. yup, same w / this ole car, after 30 years of progressively getting worse, 5 engines,and being really "put away wet" in a barn for 20 years w/every known creature in michigan as bed mates, its time to do something about it..based on all your fine input, sounds like a re- core will do the job.re. d.
            • Dennis C.
              • January 1, 1984
              • 2409
              Thanks Art. Good Choice Dennis. Best, DC
