On-Car Q-jet Tuning Suggestions? - NCRS Discussion Boards
    • 11608
    Hello All,
    Well, I had the Q-doorstop-Jet adjusted as per earlier suggestions, and the choke et al are doing very well. I have one small question that I was hoping someone could answer.
    When releasing the accelerator pedal at a slow to moderate rate after having used all 4 bbl of capability, and the rear of the carb closes (i.e. air valve shuts, and I assume rods drop back into resting position), the car will seem to surge slightly, or actually INCREASE slightly in revs.
    Does this, in your best guess indicate a LEAN or a RICH condition? And at full throttle, or partial? In other words, am I too lean at full, thus I momentarily get "more" power when decreasing the air supply when backing off and closing the rear "barrels"? Or is there some other condition causing this slight surge?
    I am just wondering whether I need to adjust primary or secondary settings, and how. Otherwise the "doorstop" has, for some strange reason, been running quite well. And this, of course, is only a minor annoyance.
    Patrick Hulst
  • Bill Clupper
    Re: On-Car Q-jet Tuning Suggestions?
    I'm sorry Patrick, but I forget the specifics of your setup, what year/engine are you running, full smog equipment in place? Probably some other things i'm forgetting, but the year of the car and the smog setup for that year come in to play. Generally, stock settings tend to the lean side in the early 70's, less so 68, '69 worse than '68 etc...
    • Bill Clupper
        • 11608
        Bill,
        I post is so much I figured everyone knew.
        71 350/270 with 2.02/1.60 valves, 212/224 duration cam with .442/465 lift. Right now I have 73/41 primary jets/rods, and I believe DA secondaries. No smogs, cuz Zora left them off!
        Externally a very correct appearing motor, with just the few minor internal changes as above.
        Patrick
          • 11608
          Bill,
          Patrick
          • Bill Clupper
            Patrick, when I had a new '74 , I was upset with the performance & I replicated the jetting from a '67 396-350hp engine and it ran like a rabbit. got approx 20 mpg on the highway also. Just a note, keep the secondary "flapper" valve spring more to the "tight" rather than the "loose" side. Also, remember to optimize the distributor curve. The '65 -365 hp curve is a good one to mimic.
            • Bill Clupper
