O.K., after adjusting the cam bolts to get the correct camber on the rear wheels, what should these cam bolts/nuts be torqued at? (55-75 lbs?) And is this the only thing that keeps the strut arm from moving? (changing camber) Is there any tricks when tightening these bolts so they won't change over time? Neg.1/2 degree camber means that the top of the tire should lean out, correct?
Thanks Ken
Thanks Ken
