Axle side yoke end play!!! - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    Re: Axle side yoke end play!!!
    Jim
    Do you know if the stub axle diameter for the Dana 36 rear is same/similar to the C2 axles? I'm wondering if the 96 snap rings (.050" - .080") would be useable in the C2 Eaton units. I haven't measured the groove width, but one of my snap rings is .059 and the other is .063. Changing snap rings for final adjustment would sure be a lot easier than yo-yoing the springs and gears to change shims.
    Steve
    • Steve D.
      • February 1, 2002
      • 990
      PS
      Does your manual give a part # for the Model 36 snap rings? I called a Chevy dealer, and he had a part # for a kit that contains 14 snap rings (2 of each thickness), but he didn't have any specs on ring or shaft groove diameter.
      Steve
      • Joe C.
        • August 31, 1999
        • 4598
        #18
        Steve:
        The clutch plates MUST be lubed during assembly with a mixture of gear oil + Special Posi Additive. When I fill the diff, I double up on the recommended amount of additive. Use the GM posi additive, from your friendly GM dealer.
        Joe
          • 15610
          #19
          Service manuals never have part numbers. Suggest you start a new thread
          asking for part number data. Joe L. can probably help out.
          • Jim T.
            • March 1, 1993
            • 5351
            #20
            Steve I do not know the answer to your question. I have owned Corvettes since 68 and have not had to get into the rear-ends. I do have parts books and owner manuals for 64, 69-70, 71, 85, and 96. I just wonder of Dana Corp would be able to answer this question?
