Well, here we go again. We've been down this path before, and at this point
I think I'm just trying to prove to myself that I'm not crazy.
I'm helping Bill Bradley write an article on Corvette positration axles and want to take another shot at the side yoke end play issue.
I recall from many years ago when I rebuilt the axle on my car that there
was a specified side yoke end play. I found the spec in a borrowed Chassis Overhaul Manual, 1971 vintage as best as I recall.
Bill's '66 Chassis Overhaul Manual has a differential side gear/differential pinion gear backlash spec range (note that this is different than the ring and pinion backlash), but no spec on side yoke end play. Incidently, the two are directly related. The '63 Corvette Shop Manual says nothing about either the differential side gear/pinion gear backlash or side yoke end play, but it illustrates the old Borg-Warner type positraction that was superceded by the Eaton design.
Joe Lucia looked at his available documentation some time ago and couldn't find a side yoke end play spec, but I want to ask everyone with a Chassis Overhaul manual from the sixties to seventies to take another look. I recall that the side yoke spec was in the axle overhaul chapter, particularly in the section on positration, and it was a note in the text, but check the specs section, too. I don't recall that there was a differential side gear/differential pinion gear backlash spec. Is it possible that the backlash spec was replaced by a side yoke end play spec in later years? As I said, the two are directly related, so if one is set within a specified range, the other should fall within a range if all the parts are within production tolerance.
We want to try and put this issue to bed if possible, but need help from the membership to research all years of the Chassis Overhaul Manual in the C2/C3 era.
BTW, this should be a great article for those of you who like to dive deep into technical details, and those of you who what to understand how a differential, in particular a positration differential, works, but never quite figured it out. Positraction axles are probably on of the least understand technologies on cars. Bill took a lot of great photos to go with the text that go a long way in helping to explain how positraction axles work, and how to do a proper overhaul.
Either respond in this thread or send me an e-mail if you find anything.
